Matty Newquay 0 Posted May 18, 2007 Um How hard is it to fit a new master cylinder?? And also will one off a mk2 golf work??? I wanna replace then servo and the cylinder as a whole unit! Anyadvice?? Cheers Quote Share this post Link to post Share on other sites
Crasher 4 Posted May 20, 2007 What Corrado do you have and does it have ABS? Why do you want to replace the servo? Quote Share this post Link to post Share on other sites
Matty Newquay 0 Posted May 21, 2007 Its a 1.8 16v! The breaks keep going spongy after about a week of bleeding them almost to the point where they dnt work at all even after i pump the pedal loads! so just wanna fix it rele someone said it most prob themaster cylinder! Just wondered if its the same as a mk2 golf! Quote Share this post Link to post Share on other sites
Crasher 4 Posted May 23, 2007 Just fit a new 22-mm m/c, they are cheap from GSF. Changing a servo takes ages and is a pain. Quote Share this post Link to post Share on other sites
Matty Newquay 0 Posted May 25, 2007 Do u think that will sort the problem?? Quote Share this post Link to post Share on other sites
