flyferrari 0 Posted June 5, 2007 Hi Guys, Will these fit onto a VR6 Corrado without rubbing.....I have no intention of doing wheel arch rolling or anything else clever! I'm thinking of putting on 205/45/16 rubber.Is that a good size and what brands/types work the best with the car? The suspension is standard VR6. I'm sorry if this is basic but I'm new to the VR6 and would like to get it right first time. Regards Kevin Quote Share this post Link to post Share on other sites
dukest 0 Posted June 5, 2007 All sounds ok to me! You're only 0.5 of an inch wider on the wheel with the same tyre width as standard so the same offset would hardly make a difference. If it did then the smallest of spacers would fix it. Quote Share this post Link to post Share on other sites
M15 VW 0 Posted June 8, 2007 flyferrari said: Hi Guys, Will these fit onto a VR6 Corrado without rubbing.....I have no intention of doing wheel arch rolling or anything else clever! I'm thinking of putting on 205/45/16 rubber.Is that a good size and what brands/types work the best with the car? The suspension is standard VR6. I'm sorry if this is basic but I'm new to the VR6 and would like to get it right first time. Regards Kevin To be honest, Id go for a 205/40/16 if you dont want a stretch to the tyre. If you do, Id go 195/45/16 on the 7j rim. Ive got 195/45/16 toyo T1Rs on my 7.5J rims and 205/40/16 avon zz3s on my 9j rims. I highly rate both of these tyres for handling etc in both wet and dry. Quote Share this post Link to post Share on other sites
vardo 0 Posted June 10, 2007 i agree with that last statement,195/45/16 i had them on my old wheels,no problems at all,and still not to harsh as the profile is still high enough! Quote Share this post Link to post Share on other sites
jinks 0 Posted June 19, 2007 Me too. I've got the 16 inch BBS splits from the mk4 golf with 195/45/16 toyo t1r's. Ithink the offset is 42 so they're extremely close to the front brakes and sit inside the arches quite a bit so look a bit toot at the moment - can anyone advise me on what spacers to use, it's not lowered yet either... Cheers Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted June 20, 2007 You can go low and out to ET35 safely with no arch work and still drive the car hard. So that'll be a 42mm - 35mm = 7mm spacer for you sir ;-) Quote Share this post Link to post Share on other sites
