H8RRA 0 Posted June 6, 2007 finally putting the corrado on the road - just drove it round the block and the windows both powered down without me touching them and won't go back up????? I would presume theres a dodgy earth on the window circuit but don't know where to start looking. any idea's - common fixes - suggestions here to start????? Quote Share this post Link to post Share on other sites
Ice White Socks 0 Posted June 7, 2007 Hi Paul, You haven't got the door cards out have you? and the switches pushed out of the way behind the door foil? I know your car is quite often 'work in progress' ! Same thing happened to me in the above situation- the switches dropped into the back of the door- got wet & windows wound up and down by themselves! If not then maybe one of the leccy window switches has failed internally? Cheers Mike Quote Share this post Link to post Share on other sites
