H8RRA
windows gone down and won't go back up!!!!
finally putting the corrado on the road - just drove it round the block and the windows both powered down without me touching them and won't go back up?????
I would presume theres a dodgy earth on the window circuit but don't know where to start looking. any idea's - common fixes - suggestions here to start?????
Hi Paul,
You haven't got the door cards out have you? and the switches pushed out of the way behind the door foil? I know your car is quite often 'work in progress' !
Same thing happened to me in the above situation- the switches dropped into the back of the door- got wet & windows wound up and down by themselves!
If not then maybe one of the leccy window switches has failed internally?
Mike
