vwdeviant 0 Posted June 9, 2007 Anyone know if Mini Rims will fit? I know they're 4x100 but can't seem to find info on offsets... Have noticed some nice BBS styled rims on Mini's recently.. Quote Share this post Link to post Share on other sites
Jim 2 Posted June 9, 2007 I remeber seeing a picture a few years ago that Darren from G-Werks took of his car on a set of Mini rims.. so i they do go on, yeah.. but not sure about ET's and whatnot though! Quote Share this post Link to post Share on other sites
Blue_Joe 0 Posted June 9, 2007 I'm almost positive that the mini rims will fit. The BBS LM's that Mike used to have on his and now on Rado_Steves are actually designed for a mini!!! Quote Share this post Link to post Share on other sites
vardo 0 Posted June 10, 2007 i work in bmw and i have tried to fit mini wheels on !they can go on but you would need to file off about4 mm off the hub hole as the mini one is too small,they fit straight on to rovers not that that helps!! :? Quote Share this post Link to post Share on other sites
Lufbramatt 0 Posted June 11, 2007 think the center bore on the mini wheels is slightly too small- to get them to fit youd have to machine off a mm or so from the inside of the wheel. also think the offset is up around 45-50 so would need spacers on the hub i expect. would look cool though i expect . . . Quote Share this post Link to post Share on other sites
Toad 0 Posted June 11, 2007 They look very much like mk4 polo GTi wheels. which would fit.... Quote Share this post Link to post Share on other sites
vwdeviant 0 Posted June 11, 2007 Am wierdly liking these wheels after I saw a Works yesterday.. Quote Share this post Link to post Share on other sites
peanut 0 Posted June 12, 2007 got a couple of mini rims here if you want to try and see what work will be needed Gav Quote Share this post Link to post Share on other sites
vardo 0 Posted June 13, 2007 i measured the centre hole today,55mm diameter,offset on the 15 inch is 45mm,offset on the 16 inch is 48mm,unfortunately i didnt have a 17 inch to check,but i reckon its 50 mm or 52mm,hope this helps you out!! Quote Share this post Link to post Share on other sites
W3RKD 0 Posted June 14, 2007 If there BBS then the odds are Yes due to there new hub centre design.. (ie just change the ally spiggot to 57.1) Quote Share this post Link to post Share on other sites
vardo 0 Posted June 14, 2007 If there BBS then the odds are Yes due to there new hub centre design.. (ie just change the ally spiggot to 57.1) all the mini wheels including the bbs are stamped bmw also and all the centre holes are fixed,no spigot rings unfortunately Quote Share this post Link to post Share on other sites
W3RKD 0 Posted June 14, 2007 If there BBS then the odds are Yes due to there new hub centre design.. (ie just change the ally spiggot to 57.1) all the mini wheels including the bbs are stamped bmw also and all the centre holes are fixed,no spigot rings unfortunately No they are not.. ALL the Mini BBS LM's i have sold are as i have explained in my post above.. Quote Share this post Link to post Share on other sites
vardo 0 Posted June 14, 2007 my mistake i aint fitted any bbs lms as yet,so wasnt aware that was so,just the offset that would need spacered out,i suppose! good to know though,are they original equipment,must look out for them, Quote Share this post Link to post Share on other sites
W3RKD 0 Posted June 14, 2007 my mistake i aint fitted any bbs lms as yet,so wasnt aware that was so,just the offset that would need spacered out,i suppose! We sell alot of BBS to the mini guys (aftermarket) and yes a 10mm spacer and you're rocking on the vw's perfectly. Quote Share this post Link to post Share on other sites
