DeanTT
Irratic temp read outs...
Hi peeps.
I've noticed a little gremlin in the last couple of days. Once the Oil is at a nice 90 deg's, the digital read out then throws a wobbly and shows it as 60 deg's, it will then climb slowy into the 70's, and then immediately back to 90. It does this at any speed :?
Also my outside temp is completely nuts! For example today, it was -15 deg's BRRRRRRR indeed.
Any ideas? Anything I can have a little tamper with??
Cheers
Other than looking for something weird interfering on the cable somewhere you can replace the coolant sensor for a couple of quid and check out the outside temp sensor connections, which is located on the front right side of the bumper i believe
