KeithC 0 Posted June 15, 2007 I'm building a Corrado Track Car and i can't deside what brakes to run. Ill proberbly be using 5stud hubs pressed into the G60 hub carrier. I can run up to 17" wheels. Will be using a Pedal Box aswell and the car should be around 1000kgs or less when built. Any1 any suggestions? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted June 15, 2007 If you're using 17s, there's plenty of choice. Budget - Bigger OE discs and calipers, i.e. 312 setup off TT/4 motion/Skoda Octupus etc etc. Midrange - Ibiza and Leon Brembo kits from Badger5.co.uk, Wilwood 4 pots, Hi Spec kits, etc. High end - AP Racing, Brembo Gran Turismo, Brembo Monoblocs, TAR-OX, Endless, Winnerpower etc Top end - Alcon, Mov-it, "Big red" setup off the 911 etc etc The benefit of all the 4 pot kits listed is reduced unsprung weight aswell as repeatable stopping power, which are important for a track car. Recommended strong and light 17" wheel to clear the brakes - Team Dynamics Pro Race 1 (same wheel as the Team Halfords BTCC integra). Recommend track pad with serious bite - Pagid RS15, aka "Pagid Greys". Also, as you're aiming for only 1000kg, don't go for massive discs, you don't need them. Focus on caliper and pad quality. HTH Quote Share this post Link to post Share on other sites
KeithC 0 Posted June 17, 2007 Cheers for the info mate. Quote Share this post Link to post Share on other sites
