sim0n_parker 0 Posted June 17, 2007 i place my key into the housing of my g60, and turn it on, i then go to click it to the start position for the starter motor, and nothing....i wiggle the key and press the wires in at the bottom of the barrel and it starts 8) now i know on the mk2 golfs there was a fault with the little plastic part where the wire connector clips on to the barrel and you change this over due to worn contacts, is this the same for the g60s? and corrados? Share this post Link to post Share on other sites
nocrap 0 Posted June 17, 2007 Yes, a very common fault and a real git to change! make sure if you buy a new one that its a VW one not some cheap tat from GSF Share this post Link to post Share on other sites
VR6 0 Posted June 17, 2007 http://www.the-corrado.net/wiki/index.p ... y:Interior Share this post Link to post Share on other sites
