tallpaul1977 0 Posted June 29, 2007 I want to completely remove my sunroof and have it welded up. Has anyone done this? Do you need to put any extra strengthing bars in? My Corrado is mainly used for track days and once the sunroof has been sorted will have a 6 point weld in roll cage installed. Cheers Paul Quote Share this post Link to post Share on other sites
davidwort 0 Posted June 29, 2007 If you simply want to weld in a sheet of steel and remove the sunroof mech then you won't need to strengthen anything, as the roof is still the same structure as if it had a sunroof in there, the roof mech frame doesn't add any strngth to the roof from what I can see. The only problem would be flexing of the roof and any filling required after welding having the potential to crack the paint around the original opening area, you'll never completely hide the appearance of it once having a sunroof but that might not matter if you're mainly interested in track days! Quote Share this post Link to post Share on other sites
kris99 0 Posted April 16, 2008 Just out of intrest were have you sourced your rollcage? I'm after a proper 6 point weld in number for proper track use. Cheers Kris Quote Share this post Link to post Share on other sites
boost monkey 0 Posted April 16, 2008 You could bond a replacement panel in instead of welding. Adhesives these days can be every bit as strong as welds are especially in shear. Quote Share this post Link to post Share on other sites
daves16v 1 Posted April 16, 2008 The roof will distort through weld heat. Quote Share this post Link to post Share on other sites
tallpaul1977 0 Posted April 17, 2008 I bought my 6 point weld in roll cage from Custom Cages, who built Ken Larks racing Corrado cage. I have now been told the roof has to be cut out to weld the cage in, so I will now be replacing the roof skin with a carbon fibre skin for looks and so I can remove the sunroof. Quote Share this post Link to post Share on other sites
was8v 0 Posted April 17, 2008 I'd tack a bracket at each corner to hold the skin in position, then use black gutter sealant to fill the gap. Will end up looking standard from the outside and will allow a bit of flex. see: http://www.clubgti.com/forum/showpost.p ... stcount=25 Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted April 17, 2008 The roof will distort through weld heat. Not if you weld in 2" sections and cool with an airline in between apparently. That's what the classic car geezer that welded my gutters did, slow but it works!!! Quote Share this post Link to post Share on other sites
Rob_G60 0 Posted April 17, 2008 The roof bars were welded on my c and thats all fine Quote Share this post Link to post Share on other sites
daves16v 1 Posted April 17, 2008 You can cut down on the distortion with an airline but the sunroof is in the middle of the roof with no adjacent stiffening as is the case with the gutters - they are close to the edge of the roof where the sheet is formed (has a bend down the length). Quote Share this post Link to post Share on other sites
