NsaneGT
VR6 OIL PUMP O RING REPLACEMENT
My apologies if this was discussed b4, But could someone tell me how eazy/difficult it is to replace that Oring? :crazyeyes:
Remove sump, remove pump, replace O ring, refit pump, refit sump.
The sump is very close to the pulley side chassis rail, so you may need to move the engine about a bit to gain clearance.
310KW VR6? That's well over 400hp.....How many Turbos have you got on that thing???
Kev
