uktarget
Fitting a bbm fuel rail
Going to fit this this afternoon
I've just been looking at the standard set-up and it has the feed to the fpr a feed to the rail next to it and then a pipe coming off the other end and going to a sensor.
As you can see the bbm rail only has 2 pipes do i need anything else to fit or do i blank off disconnect a pipe/sensor
Going to be fitted with a bbm stage 3 chip and red-tops
The fuel return goes onto the XRP fitting, then you blank off the sensor!
Cheers sam was getting a bit worried :lol:
While were here have you got a fitting piece for the induction pipe onto the standard charger
Cheers John
