u01mbp
ABS Light on: 00276 ABS Outlet Valve - Right Rear (N136)
Anyone know what I do now to get this fixed? I know nada... but I'm told by the garage that I need a new ABS pump. Is this true if I get the following vag com error: 00276 ABS Outlet Valve - Right Rear (N136)? Any tips much appreciated, Mark
More than likely your ABS ECU is full of water after the glorious dry summer we have had. Have you had any water running down the passenger
