ravaling 0 Posted July 18, 2007 any body out there have an alternative to the under carpet sound proofing Quote Share this post Link to post Share on other sites
John-M 0 Posted July 21, 2007 Well, I'm underwhelmed at the response to this - I'm looking at this same subject right now, due to a water leak into the interior soaking large areas of the under-carpet and bulkhead sound proofing/deadening stuff. If I find any decent suppliers I'll post info here. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted July 21, 2007 John - The Foam shop in Kesgrave are pretty good and usually have some off cuts lying around... I need to do something similar as the OE stuff is useless (and stinks) after it gets an water onto it... was planning just to replace with High Density foam... Quote Share this post Link to post Share on other sites
John-M 0 Posted July 21, 2007 John - The Foam shop in Kesgrave are pretty good and usually have some off cuts lying around... I need to do something similar as the OE stuff is useless (and stinks) after it gets an water onto it... was planning just to replace with High Density foam... Thanks - but does HD foam have the same sound deadening properties as the oe felt stuff ?? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted July 21, 2007 Well... not really sure, I was planning on keeping the sandbag stuff as that is fine and the compressed horse hair stuff or whatever it is seems similar to foam with regards to density and spongeyness... Quote Share this post Link to post Share on other sites
fla 9 Posted July 22, 2007 You can also use some of that Cloud 9 stuff you can get from carpet fitters. Cut it into the appropriate shape and slide it under the carpets. Pretty good, especially if you double it up. Quote Share this post Link to post Share on other sites
g60bv 0 Posted July 22, 2007 cant you just brown bread the flooring area. :? Quote Share this post Link to post Share on other sites
