rjenkins
Winter Starting Problems
Well it's that time of year again (Winter) and my Corrado is taking a long time to fire up after a cold damp night. I have been advised that this could relating to an knackered distributor cap. Has anybody else had similiar problems as I don't really want to replace the HT Leads, spark plugs etc unless I need to.
IMO it would help to replace the dizzy etc.. they were one of the first things we did when I got the car... :) I had the timming checked too, seems to be fine at 6.50am... :D (touch wood) :)
Start with the distributor cap, my 16v showed a similar problem in the winter. I also changed the battery for a bosch silver (cheap from German and Swedish) and the HT leads as it was still on the originals.
neil
Flash Red 16v
(may have seen you on 1198?)
also check that the 5th injector/cold start valve is working
What would be the best way to check the 5th injector/cold start valve
unbolt the inj...point it in a jam jar and crank the car,with a cold engine it should spary for a few seconds ONLY while the starter is working
