Ru55 0 Posted August 18, 2007 I know they're available for the mk2. Anyone heard of them for corrados? Quote Share this post Link to post Share on other sites
Mike Edwards 0 Posted August 19, 2007 The linkage is by cable, which either work fine or are broken. If you're having trouble shifting, it's more likely to be the adjustment of the cables, or bushes on the gear lever mechanism that are the problem (all of which can be caused/made much worse) by a worn gearbox mount. HTH Quote Share this post Link to post Share on other sites
Ru55 0 Posted August 20, 2007 That's great, cheers. So are there kits available for the bushes? Im not having any trouble shifting, just not happy with the amount of play. The for and aft movement i've sorted, it's the side to side movement - cable end and the bushes immediately under the gearstick that im interested in. many thanks Quote Share this post Link to post Share on other sites
Mike Edwards 0 Posted August 20, 2007 'Might' be the selector mechanism... :( Quote Share this post Link to post Share on other sites
davidwort 0 Posted August 21, 2007 do a bit of a search on the forum, you can replace a couple of plastic/bushing parts at the gearlever end for a few quid, should help remove play. try this for a start: here Quote Share this post Link to post Share on other sites
Ru55 0 Posted August 22, 2007 I'll give it a whirl, cheers! Quote Share this post Link to post Share on other sites
