Spykee
Supercharger Strip Down
anyone got any idea how to undo the pulley bolt on the G60 lump? just something to do cos i am bored and its completely knackered cos the baring had cracked through the outer casing when the belt belt shred! :cry:
i just want a look at how catastrophic the damage is!!
Big spanner and if you have a piece of poly vee belt, you could grip the pulley in a vice or with some big pipe grips.
Gavin
http://forums.vwvortex.com/zerothread?id=297812
Have a look at this thread from vortex.
Chuffing pictures have gone.
Do a search on vwvortex.com. There are plenty of pics there. If you have Broadband I could email you some. PM me
Behind the pulley should be a 2 flatenned surfaces where you can get a thin adjustable on it and then get a socket on on the main nut and give it some welly an initial impact with a hammer should be enough to undo it!
The standard pulley doesn't have the flats as far as I recall. Most smaller pulleys do have some flats.
