PAULFFC 0 Posted August 19, 2007 Before I start smashing my car up with rage :( I'm hoping someone can help :) I have managed to get the fuse box down but can't pull it far enough to get around the back to plug my spade connector for the electric seat movement and god only knows where the earth rail is. I'm worried If I yank it to much I'm going to start pulling wires put the back. Please Please give me some help cheers Paul Quote Share this post Link to post Share on other sites
JMC 0 Posted August 19, 2007 Just to check, have you unclipped the fuse box. It wont pull forward unless you do that. Have a search on here, there is a thread on it somewhere. EDIT - here it is....http://the-corrado.net/.archive/forum/viewtopic.php?f=15&t=3933&hilit=fusebox Quote Share this post Link to post Share on other sites
PAULFFC 0 Posted August 19, 2007 Just to check, have you unclipped the fuse box. It wont pull forward unless you do that. Have a search on here, there is a thread on it somewhere. EDIT - here it is....http://the-corrado.net/.archive/forum/viewtopic.php?f=15&t=3933&hilit=fusebox Hello Jmc, Thanks for the reply I have managed to unclip the fuxe box but I still can't get to the back of it without pulling loads of wires which I'm a little scared to do just in case one decides on poping out Quote Share this post Link to post Share on other sites
JMC 0 Posted August 19, 2007 Hello Jmc, Thanks for the reply I have managed to unclip the fuse box but I still can't get to the back of it without pulling loads of wires which I'm a little scared to do just in case one decides on poping out That's OK, just though i would check (mainly as it got me the first time). You should be able to ease it forward alright when unclipped. You could try and get your hand round the back (ooh er, missus) and keep everything in place when you move it. Although you should be OK (please note disclaimer - any problems arising as a result of this advice are not the fault of the advisee)..... Good luck with it. Quote Share this post Link to post Share on other sites
PAULFFC 0 Posted August 19, 2007 Hello Jmc, Thanks for the reply I have managed to unclip the fuse box but I still can't get to the back of it without pulling loads of wires which I'm a little scared to do just in case one decides on poping out That's OK, just though i would check (mainly as it got me the first time). You should be able to ease it forward alright when unclipped. You could try and get your hand round the back (ooh er, missus) and keep everything in place when you move it. Although you should be OK (please note disclaimer - any problems arising as a result of this advice are not the fault of the advisee)..... Good luck with it. I will try to easy if forward and give it ago next weekend, knowing my luck I will finally manage to the plug the connector in and find the motors on the Recaros dont work!!! Just out of interest which are of Surrey are you from as I'm in Ashtead (Epsom Downs) Quote Share this post Link to post Share on other sites
JMC 0 Posted August 19, 2007 Just out of interest which are of Surrey are you from as I'm in Ashtead (Epsom Downs) I'm at Virgina Water - just up the M25 fom you. Let me know if you are planning on coming up this way, always a pleasure to meet a fellow rado owner. Quote Share this post Link to post Share on other sites
