Tapsa Finland 0 Posted August 22, 2007 hey guys, could you give me some advices.. i'm gonna add a watercooling on my turbocharger, and i'm thinking that where would be the best place to take the hose into charger from and then take it back? should i take it to turbo from between the engine and the thermostat and then take it back to between the cooler and the engine? am i totally on wrong tracks here? every advice is appreciated a lot! Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted August 22, 2007 Not sure what you mean by "adding watercooling"? You can't 'add' water cooling to a turbo, the centre section has to be cast with the water galleries in it at the factory. What engine is it going on? If a VR6, you can use the existing throttle body coolant lines. If not, drill and tap a core plug at the back of the block on what ever engine and fit a barbed NPT fitting for your water feed, and the water return feed back to the expansion tank. Quote Share this post Link to post Share on other sites
Tapsa Finland 0 Posted August 22, 2007 Not sure what you mean by "adding watercooling"? You can't 'add' water cooling to a turbo, the centre section has to be cast with the water galleries in it at the factory. What engine is it going on? If a VR6, you can use the existing throttle body coolant lines. If not, drill and tap a core plug at the back of the block on what ever engine and fit a barbed NPT fitting for your water feed, and the water return feed back to the expansion tank. first of all thanks for the fast response! the charger (KKK26) is now at a turbo-workshop and the midsection will be replaced with a part from porsche 944 (watercooled). the engine is a 1.8T 20V (AEB) is that the only way to take water? i mean can't i take it from the same connection where the water leaves from the engineblock to thermostat? ok, so it would be wise to make it go back to system via expansion tank? thank's a lot : ) Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted August 22, 2007 Ah OK that makes sense, so you're making up a hybrid turbo? 8) The 1.8T already has water line feeds, can't you use those or did you not get all that with the engine? Yeah you can take the water any where from the main flow, perferably before the thermostat otherwise the turbo won't get any water until it opens. I suggested the core plug as it's very close to the turbo and there's always water flowing round the block with or without the thermostat... Quote Share this post Link to post Share on other sites
Tapsa Finland 0 Posted August 22, 2007 Ah OK that makes sense, so you're making up a hybrid turbo? 8) The 1.8T already has water line feeds, can't you use those or did you not get all that with the engine? Yeah you can take the water any where from the main flow, perferably before the thermostat otherwise the turbo won't get any water until it opens. I suggested the core plug as it's very close to the turbo and there's always water flowing round the block with or without the thermostat... yep, kinda hybrid! : ) oh is there. i haven't yet gave a proper look at, because the car is new and i've had lots of work to do. so there should be a plugged waterline in the engineblock already waiting for me? that would be more than nice : ) i have to give it a look, if i can find it! thanks again : ) Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted August 22, 2007 Yeah they are blue coloured if I remember correctly and one is up on the top left side of the engine near the water expansion tank. It's been a while since I looked at 1.8T properly! Quote Share this post Link to post Share on other sites
Tapsa Finland 0 Posted August 24, 2007 Yeah they are blue coloured if I remember correctly and one is up on the top left side of the engine near the water expansion tank. It's been a while since I looked at 1.8T properly! thank's a lot, i'm gonna check 'em out. they called me from the workshop and said that they'll send the turbocharger maybe today for me! JOY!!!! : ) Quote Share this post Link to post Share on other sites
Tapsa Finland 0 Posted August 31, 2007 turbo is ok now :) Quote Share this post Link to post Share on other sites
