timg60 0 Posted August 23, 2007 Hi Guys, Can someone help me, I have fitted a new bonnet today and it is all on Ok apart from the drivers side catch. When I drop the bonnet the passanger side catches but the drivers side does not. It did before so what have I done :? :? Help Tim Quote Share this post Link to post Share on other sites
g164rge 0 Posted August 23, 2007 Is the bonnet release catch fully home? I had the same prob on mine Quote Share this post Link to post Share on other sites
timg60 0 Posted August 23, 2007 Is the bonnet release catch fully home? I had the same prob on mine No idea, Where do I look? Quote Share this post Link to post Share on other sites
g164rge 0 Posted August 23, 2007 The lever you pull to open the bonnet inside.... Make sure it's fully back - towards the bulkhead Quote Share this post Link to post Share on other sites
timg60 0 Posted August 23, 2007 yup that is. bugger Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted August 23, 2007 Had this prob myself - fitted new bonnet, one pin was in line but the other was way out. Make sure the pins line up with the holes, you may have to adjust the bonnet at the hinges. I sure the pins themselves can be adjusted... possibly what is required. Quote Share this post Link to post Share on other sites
timg60 0 Posted August 23, 2007 Cheers Fella, Will have a look at that in the morning. I can still push it down by hand. Does it still sound like the same thing? Tim Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted August 23, 2007 Yeah, I had to push mine down by hand. Like i say you can adjust the pins. Sounds like one of the pins (which ever side it is) needs to be adjusted so the lock mechanism grabs the pin. Quote Share this post Link to post Share on other sites
