G60rob 0 Posted August 30, 2007 Any ideas for an easy way to install a power socket (cig. lighter type) in the boot? Anybody done this? I thought of running a wire from a spare fuse, but a) there don't seem to be any, b) the back of the fuse box is such a rat's nest of wires it's almost impossible to get at, c) where to route the wire without ripping out the interior. Quote Share this post Link to post Share on other sites
coolrado 0 Posted August 31, 2007 what are you wanting to run off it? depending on how much current you need you could just run it off the supply for the boot light. If you find a reasonably new passat estate or similar in a scrappy they have quite nice cigar sockets in the boot with a little flap over the top with 12v supply written on it, they also have a simple nut fixing on them to mount them. Quote Share this post Link to post Share on other sites
Lufbramatt 0 Posted August 31, 2007 they do those pop out sockets on vagparts.com, £20 though so probly better off getting it from a breakers. If you want it to be ignition switched then the 12v feed to the heater controls is probably a good choice, meant to carry lots of current for the heater motor. Id add another inline fuse to the added in wire though. Quote Share this post Link to post Share on other sites
G60rob 0 Posted August 31, 2007 I want to run a cool box, takes 4 Amps. Not sure if the boot light wiring would take this? Getting a socket is not a problem, Vehicle Wiring Products are good for that sort of thing, it was just that I want to simplify the wiring. The 12v feed to the heater controls sounds like a good idea, if I can find an easy way of routing the wire to the boot. Quote Share this post Link to post Share on other sites
coolrado 0 Posted August 31, 2007 the boot light wiring will easily cope with 4amps. Quote Share this post Link to post Share on other sites
G60rob 0 Posted August 31, 2007 Good, all I need now is to find out how to tap into the supply so I don't have to drive around with the boot open! Where is the switch for the boot light? I assumed it was the spring-loaded black plastic prong that sticks down from the tailgate, but I can't see any wires going to it. Quote Share this post Link to post Share on other sites
G60rob 0 Posted September 1, 2007 Answered by starting another topic. Thanks all. Quote Share this post Link to post Share on other sites
