markieshero 0 Posted October 8, 2007 Dilemma, dilemma, When I put on my indicators either right or left, both lights come on and the car goes into hazard light mode, only with slightly dimmed lights. :shock: Has anyone come across this before? Are the hazard lights and indicators on a seperate fuse? I think possibly I touching wires some where on the indicating circuit but I'll need to check this out. The problem seems to come and go but when your piling down the road its very annoying when it happens. All help appreciated!! :) :) Quote Share this post Link to post Share on other sites
dinkus 10 Posted October 8, 2007 I'd wager it's a loose connection somewhere (most likely a blown bulb) that's shorting out and causing lights to come on. If you go over a bump it moves and goes off again... Quote Share this post Link to post Share on other sites
markieshero 0 Posted October 10, 2007 Found problem, thank goodness nothing major, The indicator loom coming back from the indicator lamp was being shorted but the securing clip on the hot air return pipe going into the bottom of the air box. :lol: Required nothing more than some insulation tape. Running sweet again!! full the pipe!! :D :D :fadein: Quote Share this post Link to post Share on other sites
