Jules
Steering Vague at times
I am noticing when driving, there are times when the steering feels very vague. This happens mostly around 70mph, although I have also noticed it come and go around 30mph.
Also you can slightly wiggle the steering wheel with not much response either left or right.
I have recently changed from 7.5 x 16" wheels to 8 x 17" and I know that this probably won't be the actual problem, but might not be helping it either if there is a problem with my steering rack or something?
this subject is the bane of my life at the moment. :lol:
i've been told mine is probably the cast/camber setting
Anything between the steering wheel and the road wheels and a lot attached to those bits too..
could be:
steering column height adjuster
steering column bearings
steering col to rack UJ
rack play
track rod inner or outer joint play
wishbone bushes
suspension top mounts/bearings
dampers
ball joints
wheel bearings
and probably more
in my case most of the play was in the inner joint on the track rods, but everything wears on an old car's drivetrain
just had a thought 3corsameal, even if your alignment was done right there may be a worn component that results in alignment issues when driving and everything is under different loads.
well it could only be the rack or column as i've changed everything else :lol:
Yeah everything has been changed on mine too apart from the rack. I'm changing to my winter wheels in the next couple of weeks, so gonna see what happens then before I do anything else.
