Torsten 0 Posted October 19, 2007 some of you guys may already know what i've done to the interior of my corrado. ddi gauges and changed the lights of all switches to red. but i was always not satisfied with the hvac unti. it hasnt a smooth illumination. so i went to change this and here is a lil description of what i have done so far. first of all i bought another hvac unit the other week to modify this and keep the original untouched till its all done. i used about red 6 LED Quote Share this post Link to post Share on other sites
__Andy__ 0 Posted October 19, 2007 looks neat, some good work there. will look forward to seeing it finished.. Quote Share this post Link to post Share on other sites
Torsten 0 Posted October 19, 2007 thanks, but it will take a few days to get it back because the center console was broken in 1000 pieces when i remove the screws :( Quote Share this post Link to post Share on other sites
Torsten 0 Posted October 20, 2007 you can also use different colors like blue with red spots in the knobs Quote Share this post Link to post Share on other sites
__Andy__ 0 Posted October 21, 2007 looks kool with the diff colours, ive got the early style unit would i be able to do a similar thing with it? Quote Share this post Link to post Share on other sites
Torsten 0 Posted October 21, 2007 the early style control is completly different. there is just 1 bulb and you need a new foile with the symbols because this foile is green colored. Quote Share this post Link to post Share on other sites
Toad 0 Posted October 21, 2007 I love the blue/red unit. Quote Share this post Link to post Share on other sites
Torsten 0 Posted October 22, 2007 thank you. im doing another one at the moment (red) maybe im going to see the first red unit (a/c)... Quote Share this post Link to post Share on other sites
fla 9 Posted October 22, 2007 Did you remove the green 'spider' inside the white cover? How did you then get the side controls to light up? Looks great Torsten. Quote Share this post Link to post Share on other sites
Torsten 0 Posted October 22, 2007 i removed the siper in the red illuminated unit. But im doing another unit by keeping the spider. I think the red colored led Quote Share this post Link to post Share on other sites
Torsten 0 Posted October 30, 2007 im in the process of the second one by using the spider thingy this time. first step is done, i cracked off a lil piece of every leg and put a flat led in. the falt leds fit perfect the ports where the spider legs where pluged in. Quote Share this post Link to post Share on other sites
Torsten 0 Posted November 7, 2007 finished the 2nd hvac unit and also installed 2 LED Quote Share this post Link to post Share on other sites
IrishG60 0 Posted November 7, 2007 That is soooooo cool!!!!!... man, you should charge people for that service! 8) Quote Share this post Link to post Share on other sites
fla 9 Posted November 19, 2007 Torsten? where did you get the flat leds from? I've done a search on the web but doesnt bring anything useful up. Quote Share this post Link to post Share on other sites
Torsten 0 Posted November 20, 2007 i also hardly searched for them and found them in a german online store call Conrad unfortunately these store is very unclearly http://www1.conrad.de/ Quote Share this post Link to post Share on other sites
fla 9 Posted November 21, 2007 No worries, i'm going to use the leds in teh four locations you've shown around the centre dial. Did you use any others apart from those main 4? Quote Share this post Link to post Share on other sites
Torsten 0 Posted November 21, 2007 no, just the 4 in the spider. But the backside of the cover plate is very important for best illumination. There should be a couple clear plastic defusers snapped to the back of the plate. If the clear plastic difusers are not on just right in you can get a problem with the outter rings being not as bright. This is a function of design (light being defused from the leds only at the middle ring).... regardless of model year I would check that all the pieces that should be there are there and that they are snapped into the proper locations if the outer rings appear too dark. you also need to remove the green platic ring before of the back side on the cover plate (you can use a clear one off a mk3) Quote Share this post Link to post Share on other sites
fla 9 Posted November 21, 2007 Good info Torsten, vielen Dank. Quote Share this post Link to post Share on other sites
Torsten 0 Posted November 22, 2007 thank you :D Quote Share this post Link to post Share on other sites
cata 0 Posted November 22, 2007 Great thread Torsten! Since you are among the very few who did something about the aircon buttons, maybe you can answer an old question of mine. My buttons never light up, but my A/C setup is also incomplete. Will the buttons only light up when you turn the A/C on? If my assumptions are correct, the A/C has to be in working order for the compressor to engage the clutch and thus turn on the buttons. Is this correct? Those flat LED's are a great alternative, would you be interested in stocking up a few and selling them? It's too late for me unfortunately, I have already done my conversion and I used the clear spider (light divider) from a Passat. However, I could tell a few local dubbers about the LED's. Quote Share this post Link to post Share on other sites
Torsten 0 Posted November 23, 2007 thank you! sure can do (about the flat leds) but i dont know if they are also available in blue (for the people who wanted blue ;) ) actually the A/C buttons only light up when they are pushed / a/c is in use. the bulb in the the switch is working all the time (when cars running) but the clear plastic only allows the buttoms to light up when they are pushed you can hardly see in the pic the bulb in the middle surrounted by the yellow spider thingy. left and right side of this there are the long clear platics which carry the light to the button. there is a small part painted black / covered on this clear plastic so the light wont come up the button isnt pushed. Quote Share this post Link to post Share on other sites
