bugie
heater nutty
please help when car is warmed up the heater blows only cold air ,when moving and you give it some it starts blowing hot,then when you stop it goes back cold.also only getting a trickle of air from front and side air vents,windscreen drivers side is fine,passenger only a trickle.....thanks carl
Hi Bugie
I had similar problems myself recently.
Chuck's reply on this thread will help you alot...
http://corrado.atx-hosting.co.uk/viewto ... eater+heat
I bought a new thermostatic valve from Eurocarparts but didn't need it in the end. Just took my old one off, thoroughly cleaned it with carb. cleaner and gave it some lube then refitted it. Heater now works a treat.
New valve costs £40 or so but are easily got from scrapyards for a fraction of that.
VW Part No.191 819 911 A common to most VWs of that era.
