__Andy__
4 stud to 5 stud adaptors....
looks the dogs ding dangs, my rado is currently lowered 40mm judging by that pic id say urs is at least 60mm
i want to drop it 60mm but would i need arch work to stop the d90s from rubbing? (well tyres)
and also where can i get the adaptors from, i know they are expensive so if anyone knows of sumwhere i can get some cheaper??
i didnt have any archwork done, and it did catch when i used to go over bad bumps in the road, and i had 205/40/16s on (i think). I am also using coilovers, which is probably best so then you can just adjust the height until you gtet a good compromise between height and practicallity. There are loads of threads on here about porsche adapters and which ones to get, use the search and it will explain all!
thats kool,want a bit of stretch on the bk so im hoping that would be ok. just looking at h and r adaptors on german ebay in 25 mm u think they would stick out too much? sorry for all the questions jus need to know for deffinate before i part with the money
i think they will be ok, mine may have been 25mm adapters im not sure now, as it was a long time ago....ill read though my thread and see if i can find out...
Edit: just checked and they were 35mm adapters here is the thread if you wanted some more pics....
viewtopic.php?t=41254
