timg60
Fixing heat shield above back box.
Ok have taken the wheel off and discovered that the heatshield above the back box has come loose. Hence it sounds like someone has thrown a handfull of stones down the exhast :lol: .
How have people fixed them back on? It looks like there was a round disc fitted onto a screw on the body that held it on before and the shield has corroded around that leaving a £2 coin sized hole in the shield. Suggestions????
As the noise is driving me mad :o
cheers Tim
Find yourself a bit of alluminium, or could be any thin metal, top off a jamjar etc. Cut it into a round shape bigger than your hole in heatshield, put a hole in the middle which will fit over the pin, then use this as a washer/spacer which goes between heatshield and clip. Job sorted.
Those original round clips are about 10p from VW but as above you will need a peice in the middle if corroded / broken
The shield itself is not that much either but need to drop the box to fit...
Is there any way to remove the heat shield without removing the downpipe? I have clear access from my (emty) engine bay.
