LukeManic 0 Posted December 27, 2007 Hi guys, I've got a Phoenix Gold Octane R 5.0.4 amplifier (http://reviews.cnet.com/car-amplifiers/phoenix-gold-octane-r/4507-6726_7-30844528.html?tag=sub) I want to install it in my rado, it will be running 2 6x9s and a 10" sub. It has two 25a fuses on it - does this mean I need a 50a inline fuse on my power cable? As I currently have a 10 gauge power cable with a 30a inline fuse, just wondering if this will be safe to use? Thanks in advance, Luke. Quote Share this post Link to post Share on other sites
slats 0 Posted January 3, 2008 http://www.the12volt.com/info/recwirsz.asp I would go a minimum of 8 gauge and best would be 4 gauge as then you have no chance of melting the cable and if you ever need to add an amp you have the capacity!! Quote Share this post Link to post Share on other sites
Lufbramatt 0 Posted March 12, 2008 ive got some 25mm^2 welding cable running my amp (which incidentally is the same as yours) and its fine. Got it cheap from ebay, works out about equivalent to 3 guage AWG, and the insulation is nice and bendy so its easy to route through the car. And its black which i prefer in the engine bay, didnt want bright blue/red cable running through there! the manual for the amp suggests to use 2x20 amp ATO fuses, so i used a 40 amp AGU fuse and its been fine. BTW i have a scan of the manula for the amp. if you need it, pm me your email address. Quote Share this post Link to post Share on other sites
