Patch 0 Posted March 12, 2008 My left side light doesn't work,however the brake light does.Any idea's as to what it could be? Does the side light have it's own fuse? Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted March 12, 2008 Is there 2 elements in the bulb, one for side lights the other for brake. Or is it just the one element that gets brighter for the brake light? Quote Share this post Link to post Share on other sites
Dec 1 Posted March 12, 2008 Could be as simple as one of the two filaments in the bulb being broken. Try the easiest and cheapest fix first, just swap the bulb for a new one! ;) Quote Share this post Link to post Share on other sites
Patch 0 Posted March 12, 2008 It's the twin filament type,tried new bulbs and tried a new bulb holder.Any other idea's? Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted March 13, 2008 Does the other side work fine? Quote Share this post Link to post Share on other sites
mattnorgrove 0 Posted March 13, 2008 Fuse number 8 is for tail and side light left side, check your sidelights at the front (one click on the switch). If your left sidelight is out too, then its fuse number 8 (10amp btw). HTH Quote Share this post Link to post Share on other sites
Patch 0 Posted March 13, 2008 Interesting,sometimes my front left side light works,sometimes it doesn't.Rear left side light never works?!!! Quote Share this post Link to post Share on other sites
mattnorgrove 0 Posted March 13, 2008 I'd change the fuse then, or just check how it's seated, if the left front sidelight's affected too, then sounds like a fuse issue... Quote Share this post Link to post Share on other sites
Patch 0 Posted March 13, 2008 Now the daft question,where is the fuse box? Please excuse my naiveness,not had the car long. Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted March 13, 2008 Look under the steering wheel mate, there's a shelf and to the far right theres a small shell. Take that out by the 2 twist clips and it pulls out. The fuse box is behind it. Quote Share this post Link to post Share on other sites
Patch 0 Posted March 15, 2008 Yep,it was the fuse.Swapped it over now.Cheer's guys. :notworthy: Quote Share this post Link to post Share on other sites
