swiftkid
Unhelpful washer jets
Im not really sure which section this should be in but just recently my car has developed a rather annoying habit of setting the washer jets going on its own and then keeping them spraying. I can stop it by flicking the stalk back a little bit but it seems to come on when go over a bump in the road.
As you can imagine this is incredibly annoying!!! Its a 1.8 16v early spec, i fitted a new adjustable steering column replacing a non adjustable one following a theft attempt and the wires are a bit tight but that was a while ago and its been fine.
Any help would be much appreciated. Cheers!!!
loose connection in the steering column bythe sounds of things.
or your jets are possessed by the ghost of OCD and needs to wash your windscreen 15 tmes a trip?
