Spicy G60
Early to late door cards
I need some help :(
I've just bought a late interior for my early corrado and the electric wndows and mirror switches are different.
I've found how to change tohe mirrors from early to late but cant find anything for the window switches.
If any one coulds help me with this I would be very greatfull
Thanks
I've done it with mine, but a long time ago. Try this.... http://www.the-corrado.net/.archive/forum/viewtopic.php?t=27329&highlight=
I seem to recall there was something slightly different that needed doing on the drivers side as Daves instructions came fom a LHD wiring diagram. If it was done as it then the buttons on the drivers side ended up the wrong way round (i.e. the one on the left operated the drives side and the one on the right the passenger side - if that makes sense). If I find anything further on it I'll let you know....
I've got this setup on mine, but unfortunately changed before I bought the car. If you need any pics I could help you out, but thats probably as much help as I can be
Right, dug out some old paperwork - seem to recall you need to swap pin 2 and 5 on the drivers side one, from the information given in the other link. This make sure that the rh switch operates the driver window and the lh switch the passenger window. Of course I could be wrong - it was 4 years ago that we did this :cuckoo:
Thanks John
This will help me alot. Just waiting for the connectors now and I'll get the soldering iron out and start burning my fingers :D
Thanks Steve
