J Collins 0 Posted November 25, 2003 My C sat for 4 months without a start. I've changed the plugs and wires, distributer and rotor,fuel filter and also changed the fluids. The engine will turn but will not start. Any suggestions? Thanks, John Quote Share this post Link to post Share on other sites
Henny 0 Posted November 25, 2003 OK, assuming that the car ran perfectly before the 4 month sleep... Take all 4 plugs out, disconnect the coil -> distributor wire at the coil, put a rag over each of the plug holes and turn the engine over with the starter for 10 - 15 seconds.... Throw the rags away, put the plugs back in, re-connect the coil wire and try it again... Odds are that you've got stale fuel in the cylinders which just isn't getting cleared out properly. If that doesn't clear it, answer these questions: Does it even sound like it's trying to fire at all? Is there a spark at each plug? Is the fuel pump running while cranking the engine? If all of these are YES, then you may have to bump start it by towing it with another car... Could be that the starter can't quite spin the engine fast enough to get her started... :? Good luck anyway... 8) Quote Share this post Link to post Share on other sites
J Collins 0 Posted November 25, 2003 Thanks, I'll give it a go. Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted November 26, 2003 had similar problem with mine, it was the ignition switch, quite common so im told, new switch is only about £16 from VAG, Quote Share this post Link to post Share on other sites
J Collins 0 Posted December 22, 2003 Thanks for the responses. She's ALIVE :D Quote Share this post Link to post Share on other sites
Furkz 0 Posted December 22, 2003 if its the switch sometimes u can start the car by pressing the key down HARD whilst turning Quote Share this post Link to post Share on other sites
Henny 0 Posted December 22, 2003 J Collins said: Thanks for the responses. She's ALIVE :D Any ideas what it was in the end? Glad it's working anyway.... 8) Quote Share this post Link to post Share on other sites
J Collins 0 Posted March 22, 2004 Plug wires in the wrong firing order :roll: Quote Share this post Link to post Share on other sites
