Lora_G60
Taking a front bumper off a corrado
I am trying to take my front bumper off the corrado.
Does anyone know how to do this?
Its a 2.0 16v corrado
I'ce had it jacked up today and can see some bolts near the front crossmember. is it these bolts you remove?
Thanks
Baz
Three bolts either side of the crossmember,two larger ones you remove NOT the inner small ones,i would support the engine if i was you as the inner M8 bolts mounts tend to rust away,so you will have an engine on your head and that will hurt....this has been covered many times :sleeping:
Soooo many threads you'll be glad to hear.
Go to advanced search, type in:
+remov* +bumper
(can add in +front as well if you like)
Restrict to the Exterior forum and return threads rather than posts.
It's basically 4 bolts (2 for each side) but a picture paints a thousand words, so I'd suggest the search option.
You need to remove the metal bracket that holds the bottom of the bumper and spoiler to the rad support crossmember (5 x 10mm head I think)
Then the 4 (2 each side) x 17mm headed M10 bolts which go thru the engine front crossmember - you must support the engine when removing the bumber and never attempt to drive the car without!!
You might have to remove a couple of the 8mm bolts holding the arch liners on so you can pull the bumper fwd and round these, then it's just a case of unplugging the lights (you may need to release the wiring depending on what year it is or just disconnect the bulbs from the indicators. Really need 2 people as it's heavy!
Thank you very much, This confirms what I thought.
Thanks you, Will be removing it tom night now as cant be bothered now.
Cheers
Baz
