KipVR 1 Posted April 8, 2008 All the sound deadening stuck to the underside of my bonnet has degraded and is dropping all over the engine bay, my local dealer has quoted £70 :shock: for a replacement set of panels, has anyone else used any alternatives? I want to keep it as it does soak up al lot of the engine sound keeping it quieter in the cabin. Quote Share this post Link to post Share on other sites
shawshankkid 1 Posted April 8, 2008 viewtopic.php?f=15&t=62724&st=0&sk=t&sd=a&hilit=noisekiller Got it on My G60.....brilliant product. Quote Share this post Link to post Share on other sites
Alexander 0 Posted April 8, 2008 I've got noisekiller under my G60's bonnet. Doesn't make it silent by any means but definitely muffles it. And it looks cool. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted April 9, 2008 I used a roll of Dynamat hoodliner on mine. I carefully removed the old crumbly panels and used them to cut new templates. Easy peasy. The hoodliner has been stuck on my bonnet for a good few years now I reckon, over a year of that suffering turbo heat and the glue is still bonded like barnacles to the bonnet. Awesome stuff. Quote Share this post Link to post Share on other sites
KipVR 1 Posted April 9, 2008 Sound waves are only absorbed by non reflective surfaces which is why the VAG stuff is like a waffle and is open cell foam. So how can the shiny alternatives work with a reflective surface? Surely that's meant for a bulkhead -to reflect the sound and heat back into the engine bay?? It's a bit like when you drive your car over grass the engine sounds much quieter then on tarmac because the sound is absorbed by the grass but reflected by tarmac....... Quote Share this post Link to post Share on other sites
C. Will Corrado G60 2 0 Posted July 7, 2008 I'm looking to re-new my under bonnet foam and would like to know if the VR6 foam will fit on a early G60 bonnet. Also been reading up on here about Noisekiller and Dynamat (is that how you spell it) products, which is best? Chris Quote Share this post Link to post Share on other sites
boost monkey 0 Posted July 7, 2008 I'm looking to re-new my under bonnet foam and would like to know if the VR6 foam will fit on a early G60 bonnet.Chris Yup, same part number for early and late Chris: 323 863 950 Quote Share this post Link to post Share on other sites
C. Will Corrado G60 2 0 Posted July 7, 2008 I thought the under side was different though? Anyone got photos of the undernether of a early & late Bonnet? Quote Share this post Link to post Share on other sites
boost monkey 0 Posted July 7, 2008 Part number was checked against a 1991 Corrado and a 1994 Corrado, I doubt they would made the foam a different shape, there seems to be no reason for it. Quote Share this post Link to post Share on other sites
C. Will Corrado G60 2 0 Posted July 7, 2008 Having not own both cars I can't say for sure but I thought they were slightly different supports for the VR6 bonnet. Could be totally wrong! Anyone got a photo of both? Quote Share this post Link to post Share on other sites
Dec 1 Posted July 7, 2008 Check the link in shawshankkids post above ^^^^ Definitely different patterns! :wink: Quote Share this post Link to post Share on other sites
boost monkey 0 Posted July 7, 2008 I guess VAGCAT is wrong then :roll: Quote Share this post Link to post Share on other sites
C. Will Corrado G60 2 0 Posted July 7, 2008 I guess VAGCAT is wrong then :roll: YEP just seen this topic, check out the first post. Quote Share this post Link to post Share on other sites
boost monkey 0 Posted July 7, 2008 I guess VAGCAT is wrong then :roll: YEP just seen this topic, check out the first post.[/quote:2ogwgbrg] Not sure what you're referring to mate :scratch: Quote Share this post Link to post Share on other sites
shawshankkid 1 Posted July 7, 2008 Noisekiller is very very good, still looks like the day i put it on and really does what it says on the tin. Worth every penny. :D :D Quote Share this post Link to post Share on other sites
C. Will Corrado G60 2 0 Posted July 8, 2008 just spke to them on the phone and they seem really helpful, they're sending me a template so I can check it fits before I buy. :D :D Quote Share this post Link to post Share on other sites
