PROVR6
Will a MK5 Gti Steering wheel fit my C?
Ive been reading the following thread with some interest http://www.the-corrado.net/.archive/forum/viewtopic.php?f=19&t=46242&start=15&st=0&sk=t&sd=a&hilit=tt+steering+wheel.
My question is, Will the Mk5 Gti Steering wheel just slide on like the standard wheel. Im not worried about using the horn. My other question is how does the air bag fit in the center section, again I don't want it to work just to look right. Read somewhere that you might have to debag it, is that easy or necessary?
Im sure someone must have one or a late style wheel on their corrado.
I gave it some thought recently. Wheel size is good but whether it fitted was always a bit of a grey area. I considered mounting an aftermarket boss slip ring to a modern wheel to rig up a horn but went cold on the idea. Id be interested in the results if you give it a go.
I think it probably will fit, but they're stupidly expensive and think they might look a bit too big.
The thing that put me off in the end was getting the electrics hooked up :(
