chrisr
hand brake
my hand brake is struggling to hold my car, its had new rear discs and pads previously, im just wondering can i adjust the hand brake at all as when its on its pointinng towards the sky :?
If you remove the center tunnel cover (1 screw under rear ashtray/1 screw under handbrake handle) you can wind the nuts up on the cables, they are more than likely stretched though...Loads of corrado's seem to have stretched cables for some reason...
Neil.
