Riley
Do the vr6's have a built in immobiliser?
Well I hope this takes it forward a bit.
ECU pin data for VW - http://derby.polog40.co.uk/~paul/pindata_vw.pdf go to p30 for vr6.
AFAIK its a grey/white wire for the K line and yellow for the L line, try hooking up directly to the vag com wire along with any 12v and ground as per the connector pinout in my previous post.
See also:
http://forums.vwvortex.com/zerothread?id=3799758
http://forums.vwvortex.com/zerothread?id=3798799
You may not need to hook the L line up, as just the K line is for comms, L "wakes" the ecu or something. Also make sure these comms wires arent grounded elsewhere or they wont work.
Am I right in thinking that absolutely none of the late factory VR6's have the old-style fob & dash socket type immobilsers? Factory was chipped keys?
Soooo... if a vehicle has the fob plugin de-activation type then the factory immob part of the ECU must have previously been bypassed, so now easier to replace what's currently there with a Cat 1 alarm/immobiliser?
