Talc 0 Posted June 23, 2008 This is getting stupid, Got the MOT next week, so went through to check that everything worked: horn doesn't work, checked all of the fuses, pulled steering wheel apart and cleaned the points, checked cables connected. Now, i'm trying to find the actual horn unit, its not behind the grill, not behind the fog lights, not behind the dirt covers in the wheel arches, not anywhere apparent in the engine bay... LHD 92 vr6... Help. :confused4: Quote Share this post Link to post Share on other sites
Dec 1 Posted June 23, 2008 hmmmm.......I always thought that both horns (high/low tone) were behind the front grille! That's the only place I've ever seen them, but I have only owned early spec rados! :? Quote Share this post Link to post Share on other sites
STU175 0 Posted June 23, 2008 had same problem last week. found two seperate horns behind front grill disconnected one of them and the other worked?! worked for me and got me through the MOT?? Quote Share this post Link to post Share on other sites
boost monkey 0 Posted June 23, 2008 IIRC, there were a set of horns underneath the O/S front wing from that 92 plate I cut up. There also seem to be horns behind the grille on my 90 plate. Perhaps Dec is right and grille horns are early, and wing horns are late? :shrug: Quote Share this post Link to post Share on other sites
junkie 0 Posted June 23, 2008 Mine is an early and was behind the grill but now under the N/S wing area Quote Share this post Link to post Share on other sites
paul20v 0 Posted June 23, 2008 n/s wing behind the bumper from underneath 94 vr. Quote Share this post Link to post Share on other sites
gsbellew 0 Posted June 23, 2008 I've had 6 early Corrado's and all had two horns behind the grille, the late one I have now does not have them there, I'll have a look tomorrow and see if I can find out where they / it is / are. Quote Share this post Link to post Share on other sites
boost monkey 0 Posted June 23, 2008 yes N/S, not O/S :brickwall: Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted June 24, 2008 passenger side i call it, on a RHD car, saves confusion Quote Share this post Link to post Share on other sites
boost monkey 0 Posted June 24, 2008 I'm just being a tard! Nearside and Offside and easy enough to remember I reckon, I got confused cos the car was on it's roof when I took the horns off :nuts: Quote Share this post Link to post Share on other sites
n3p 3 Posted June 24, 2008 Do the factory corrado's have both the high and low tones connected? I disconnected the high one, sounded a bit too :camp: Quote Share this post Link to post Share on other sites
boost monkey 0 Posted June 24, 2008 :shrug: Only my high tone works. I never press the horn. Quote Share this post Link to post Share on other sites
