devnull 0 Posted December 4, 2003 Just after installing my new clutch, now my speedometer doesn't work. On my car ('92 VR6),it appears to be an electronic device (?) as opposed to cable driven. The only obvious plug on the tranny is the one right near the shift linkage. This may not even be the source of the speedometer's sensory input. If anyone knows whether or not this is the appropriate place, or if not, where I can find it, that would be most helpful. The Bentley doesn't seem to give much of an obvious hint as to where the bugger might be located. Thanks in advance! Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted December 4, 2003 Just after installing my new clutch, now my speedometer doesn't work. On my car ('92 VR6),it appears to be an electronic device (?) as opposed to cable driven. The only obvious plug on the tranny is the one right near the shift linkage. This may not even be the source of the speedometer's sensory input. If anyone knows whether or not this is the appropriate place, or if not, where I can find it, that would be most helpful. The Bentley doesn't seem to give much of an obvious hint as to where the bugger might be located. Thanks in advance! That's the vehicle speed sensor (G68) alright, towards the rear of the gearbox.. A largeish black fella with the plug pointing toward the engine block. Check you didn't bust the wires when the tranny came off. Kev Quote Share this post Link to post Share on other sites
