stevelknievel 0 Posted July 24, 2008 on my 94 the previous owner said the motor was seized. well after getting it home and turning the motor over with a breaker bar i've ruled that out. now that the battery is charged i tried to turn it over and all we hear is a click when i turn the key over. and when i turn the key over and the key goes back to on i cannot try to turn the motor over again. it locks and i have to turn it all the way off then on again. is this a common problem in the starting system? thanks in advance Quote Share this post Link to post Share on other sites
mattkh 0 Posted July 24, 2008 . and when i turn the key over and the key goes back to on i cannot try to turn the motor over again. it locks and i have to turn it all the way off then on again.is this a common problem in the starting system? thanks in advance Hi It is not a problem. It is Normal. Where did you connect the breaker bar to turn it over. Quote Share this post Link to post Share on other sites
stevelknievel 0 Posted July 24, 2008 i turned it from the crank pulley Quote Share this post Link to post Share on other sites
mattkh 0 Posted July 24, 2008 Hi Looks like you have a lazy starter. You need to take it out and just clean the shaft. What car is it. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted July 24, 2008 Check the battery voltage first. You need at least 11.8V to turn the engine on the starter. Quote Share this post Link to post Share on other sites
red-rado 0 Posted July 24, 2008 Agree with the above. Thats a normal feature of the ignition barrel to stop you trying to start a car thats already running (sounds silly but ive seen it done, especially on new cars that are too quiet to hear.) Check the battery voltage and then whip the starter motor off and inspect it. Check the teeth on the starter motor and the flywheel for scores/wear. Then if its all normal, clean it up and give it a very light coat of grease on the moving parts to ensure smooth operation. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted July 24, 2008 its not something daft like immobiliser is it? Quote Share this post Link to post Share on other sites
stevelknievel 0 Posted July 24, 2008 thanks for the help guys ill check the batt voltage and starter tonight. oh and its a 94 corrado with the VR6 Quote Share this post Link to post Share on other sites
Pondy_p 0 Posted November 16, 2008 Hi All I have similar problem where the ignition just does nothing. I switch it on the fuel pump primes and for the immobiliser on the car I have to wait for the oil light to stop flashing. When turning the key to start absolutely nothing happens, maybe a soft whurring. On a few occasions previously when starting it did make a fast grinding noise only just conected this happening with this latest problem - I replaced the ignition switch (also charged battery, but only 1yr old) and also spotted the cable straight from the +battery terminal to the starter was virtually broken so replaced that too. Is the starter motor knackered? If so I am reluctant to try to take it out as this may lead to alignment problems - Any pointers or tips, please? :shrug: Quote Share this post Link to post Share on other sites
mattkh 0 Posted November 16, 2008 Hi Clean and tighten the spade connector to the starter solenoid. Quote Share this post Link to post Share on other sites
