NMPHHL
front wipers stop halfway
HI
I ve just bought the 90 g60 .the best car .My front wipers stop halfway @ off position when turned off .when it is on works fine cover all area. Any body knows what is wrong with it. Relay or motor ??
**MOD EDIT - I've removed the duplicate thread on this topic, and moved my reply to this one instead!**
NMPHHL, Do they always stop in the same place, or just where you turn them off?
If they stop in the same place every time, I'd say that the arm that's attached to the motor has slipped so that the park position has moved. It's pretty easy to reset it if this is the case, you need to undo the arm from the motor when it's at the stop position, move the wipers to the proper parked position, then re-attach the arm. I've never done one on a 'rado before, but I've played with a few on Golfs and it's pretty easy. 8)
If the wipers are just stopping as soon as you turn them off, then you've got a fault with the park sensor, I'm not sure where this is on a Corrado, but I've no doubts that someone here will know! :wink: 8)
please somebody post this up cos mine do the same :cry:
Same as what? Stopping in random places, or stopping in the same place every time, just not where you think it should?
Any info you can give will help find the cure... 8)
