welshconan 0 Posted August 8, 2008 Hey Chap's I'm after a bit of advice on how to remove my stickers on the exterior of my Corrado. I have VW sticker's that runs above the sills and also the length of the sills. They are starting to look really tacky and I want to remove them myself this weekend. How do I go above this? Any advice welcome, plus will the paint work under the stickers be OK? Cheers Lee Quote Share this post Link to post Share on other sites
dinkus 10 Posted August 8, 2008 I'd use a hot air gun set on a low setting or a hair drier to heat them up and you should be able to carefully peel them off. You'll probably need some sticky stuff remover to get the gunge off after - have a look in Halfords to see what they've got. As for the paintwork - that's really going to depend on how long they've been on there. If you're lucky, the paint will be fine and just needs a wash, if you're not the paint might have faded everywhere apart from under the stickers. Quote Share this post Link to post Share on other sites
welshconan 0 Posted August 8, 2008 Cheers By the state of them, they have been on since the car was new. OK - I'm gonna give it a blast and hopefully the paint is fine under the stickers. Lee Quote Share this post Link to post Share on other sites
