foster 0 Posted August 27, 2008 Hello Im looking at getting some wheels that have a centre bore of 54. As I understand the corrado is 57 what are my options? I think Im going to be fitting spacers so do some exist that change the bore size? Or will I have to have the centres milled out? Thanks. Quote Share this post Link to post Share on other sites
Guest Posted August 27, 2008 vw centre bore is 57.1, only option you have is to have them machined, but make sure you calculate the off set correctly, as with some wheels (depending what they are off?) you may still need to run hub adaptors for the correct 4x100 or 5x100 bolt pattern and to get that right may? push the rims out further 9closer to the arch) and cause more problems Quote Share this post Link to post Share on other sites
foster 0 Posted August 27, 2008 The wheels are definatly 4x100 so I dont need to worry about that. Does anyone know if schmidt use spigot rings or if they make the wheels fit you're hubs without. Thanks again for you're help bud. :D Quote Share this post Link to post Share on other sites
