loopylindsay
what bulb code? FOR HID
i have not got them on mine but i beleve you can get xenon or bi xenon hids the bi ones being hi and low
but if your running inpros unless you have moded them you dont need bi xenon as they go out on high beam
h7 is a single light beam if you get what i mean
you will have a 501 or 203 sidelight bulb (if its push in then its 501 - push and twist with a bayonet base its 203)
h4 65-55watt bulbs which is 55watt low beam (driving round town) 65watt or 60watt Hi Beam (country roads when you flick em on)
if you have H7 bulbs they are 2 prong and are 55watt as standard, in this case chances are you will have 2 in each headlamp-
unless
501 or 203 for sidelight
h7 for main beam
h1 or h3 for full beam - H3 being lamp with a wire on it ( usually fog light bulb)
H1 being single contact slim long bulb
any more questions or quieres just ask :p
