PROVR6 0 Posted September 14, 2008 Ive been touching up my stone chips and resprayed the underside of the cill sections where the paint has been eroded by salts and chipped. The piece of Trim under the Front Grill is absolutely peppered with chips and would take forever to touch in. It seems very loose but dosen't pull out. Is it easy to remove as Id like to fill the chips and spray it? Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted September 14, 2008 its part of the front pannel mate,if its loose then the hole front end is loose..... Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted September 28, 2008 What he said ^^^ Its the same part the grille and lights are attached to if you lift the bonnet you will see. Why would it be loose though? Quote Share this post Link to post Share on other sites
