Adz The Rat
VR6 Running Temps??
Mine usually sat at just over the 70 mark on the temp gauge, rose to about 100 when sat in traffic for ages.
Since Saturday its now started running about 90-95 under normal driving and when sat about in Blackpool it rose to 110, I then put heaters on full and could hear the fan working so the temp dropped.
What is normal temp for these engines??
Also, is there a way to get the fan to kick in lower and stay on for longer? Mine only stays on for a few seconds at a time and isnt enough really
110 is a bit high, any more and you'll start to do some damage.
search for the 'defintive cooling' thread, but mayhap a temp sender has gone.
There are tons of thread about this already chap.
search.php?keywords=%2Bvr6+%2Btemp*&terms=all&author=&fid[]=1&sc=1&sf=all&sr=topics&sk=t&sd=d&st=0&ch=300&t=0&submit=Search
search.php?keywords=%2Bvr6+%2Btemp*+%2Brad*&terms=all&author=&fid[]=1&sc=1&sf=all&sr=topics&sk=t&sd=d&st=0&ch=300&t=0&submit=Search
For example:
viewtopic.php?f=1&t=68613&hilit=+vr6+temp%2A
