GRINGOG60 0 Posted December 9, 2003 Chaps, When i go on long drives sometimes i have niticed that when i turn the heater on it starts off hot and then goes cold- this has only started happening since the weather turned sh**ty - anyone had this before? could be the thermostat having stuck closed? it never does it on short journeys though but when the engine goes above about 106C it starts happening... i had this same problem on a 16 valve Mk2 Golf GTI that i had once but i never fixed it and just sold the car (to a mate ha ha :twisted: ) An of you guys got any ideas? + has anyone got the part number for the lower temp fan switch(180 degrees)???? Quote Share this post Link to post Share on other sites
Ice White Socks 0 Posted December 9, 2003 Hi, Whilst I would guess it would be more an air lock than anything else, I would get the stat checked just in case. My stat disintegrated last week and locked shut- needless to say what followed involved lots and lots of steam action :shock: I was lucky that I was only twenty yards away from a VW specialist- otherwise it would have been a long wait and a big recovery fee. Cheers Mike Quote Share this post Link to post Share on other sites
GRINGOG60 0 Posted December 9, 2003 Anyone know where the thermostat is on the G60- is it on the front of the block where the two o-ring sensors goin in to a black plastic housing at the top near the cylinder head ?- ive just replaced the main bearing shells in my pit in my garage last sunday and i really dont want the the lump getting to hot knackering the new shells. Quote Share this post Link to post Share on other sites
h100vw 0 Posted December 9, 2003 No it's in the front, under the charger. Plastic elbow coming off the pump. Access from underneath. Gavin Quote Share this post Link to post Share on other sites
GRINGOG60 0 Posted December 9, 2003 Cheers Gavin i'll have a ganders tonight mate Can ayone help with the lower fan temp switch part no. or what car it would come off - MK2 Golf GTI 8v? Quote Share this post Link to post Share on other sites
GazzaG60 0 Posted December 9, 2003 and remember the pump needs 2 outlets plus thermo not 1(a lesson learned after 6hrs of stripdown fun. Quote Share this post Link to post Share on other sites
GRINGOG60 0 Posted December 9, 2003 and remember the pump needs 2 outlets plus thermo not 1(a lesson learned after 6hrs of stripdown fun. Im not sure what you mean mate? Quote Share this post Link to post Share on other sites
h100vw 0 Posted December 9, 2003 I do tho having sold him a pump for a carb car. Sorry mate!!! :oops: There should be 3 outlets down the side of the pump not two. Including the thermostat elbow in both cases. Gavin Quote Share this post Link to post Share on other sites
GazzaG60 0 Posted December 9, 2003 sorry i didn't read the original properly. i thought you were doing a pump change. a lovely job esp at this time of yr. Quote Share this post Link to post Share on other sites
chuck 0 Posted December 10, 2003 Can ayone help with the lower fan temp switch part no. or what car it would come off - MK2 Golf GTI 8v? you really need a lower temp thermostat too, otherwise your fan will be on constantly (it knackered my fan with a standard thermostat and lower thermoswitch after a couple of months). The lower temp thermoswitch I used was from a VW transporter. Part number is 251 959 481K (or 701 959 841) with temp ranges of 87-76'C/93-82'C. Also see http://corrado.atx-hosting.co.uk/viewto ... ermoswitch. By the way, your heater problem is probably caused by (if not an airlock), a sticky inlet valve. Check the inlet pipe on the engine side of the bulkhead - there should be a silver valve (adjacent to a black one on the outlet pipe). Take it out and stick a straigh thru pipe on. If this fixes it it need a new silver valve. Its designed to prevent excess water pressure from bursting the heater matrix by closing when the temp gets high. This definately applys to 16v's, I dunno if the same system is used on the G60, but it must be similar as its the same heater. Quote Share this post Link to post Share on other sites
