jamin 0 Posted May 11, 2017 Looking good mate, ride hight looks spot on Thanks, i'd like to take the front a little lower, but then i'd have to remove the inner arches and I dont really want to do that. Would also like to space the rear wheels our further, but I think the minimum for hub centric spacers would be around 25mm and that would be too far. Quote Share this post Link to post Share on other sites
Jim 2 Posted May 11, 2017 Looks cracking :) Nice consistent numbers on the compression check too which must be reassuring :) Quote Share this post Link to post Share on other sites
jamin 0 Posted May 11, 2017 Looks cracking :) Nice consistent numbers on the compression check too which must be reassuring :) Yeah, definitely, also passed the MOT fine, only 2 minor notes about the rear brake lines, which they cleaned up anyway so more than happy with that. Quote Share this post Link to post Share on other sites
odub 0 Posted May 11, 2017 looks great, i'll keep an eye out for you. I've got some 11mm hub centric spacers on mine. Can send you a link if you're interested Quote Share this post Link to post Share on other sites
jamin 0 Posted May 11, 2017 looks great, i'll keep an eye out for you. I've got some 11mm hub centric spacers on mine. Can send you a link if you're interested Yes please, I'd like to see what they look like. Quote Share this post Link to post Share on other sites
coullstar 0 Posted May 11, 2017 Looks nice, is it Aqua blue? Quote Share this post Link to post Share on other sites
odub 0 Posted May 11, 2017 http://www.st-suspensions.net/wheelspacerfinder/ part number D2 SET 56020078 it says 23mm but that is 11.5 per side Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted May 11, 2017 ive just put 10mm hubcentric's on my VR,which is lowered on KWV1's to a 2 finger gap between top of tire & bottom of arch, so as to fit the hispec 4 pots.....ive noticed if i go over a small hump backed bridge a little too quickly the weight on the downward travel is enough to cause a tiny rub on the outer tire edge that is with OE speedlines Quote Share this post Link to post Share on other sites
jamin 0 Posted May 11, 2017 Looks nice, is it Aqua blue? Certainly is, which is the best colour i'm lead to believe ;-) http://www.st-suspensions.net/wheelspacerfinder/ part number D2 SET 56020078 it says 23mm but that is 11.5 per side Thanks, I will check them out. ive just put 10mm hubcentric's on my VR,which is lowered on KWV1's to a 2 finger gap between top of tire & bottom of arch, so as to fit the hispec 4 pots.....ive noticed if i go over a small hump backed bridge a little too quickly the weight on the downward travel is enough to cause a tiny rub on the outer tire edge that is with OE speedlines Thanks for the info! Quote Share this post Link to post Share on other sites
jamin 0 Posted May 11, 2017 ....'Ferrado' as that is what my youngest son calls it :-) Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted May 11, 2017 Certainly is, which is the best colour i'm lead to believe ;-) Thanks, I will check them out. Thanks for the info! no danger thought it might be worth mentioning. i have been slowing for the hump back lately but may raise the front a little to accommodate a bit more suspension travel Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted May 11, 2017 ....'Ferrado' as that is what my youngest son calls it :-) you could tell him that Mr J Clarkson called it a 20 grand ferrari back in the day ;) Quote Share this post Link to post Share on other sites
jamin 0 Posted May 11, 2017 you could tell him that Mr J Clarkson called it a 20 grand ferrari back in the day ;) Ha, so it seems he is right then!!! Hahahahaa Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted May 12, 2017 Ha, so it seems he is right then!!! Hahahahaa indeed lol FYI i had a better look at the VR front under arches last night - quite a scuff on the arch liner & a few noticeable scuffs on the tires too. think i need to raise it up a tad because of the 10mm spacers Quote Share this post Link to post Share on other sites
jamin 0 Posted May 12, 2017 indeed lol FYI i had a better look at the VR front under arches last night - quite a scuff on the arch liner & a few noticeable scuffs on the tires too. think i need to raise it up a tad because of the 10mm spacers I'd like to see a pic of the spacers fitted if you adjust the suspension...I'm still not convinced of their fitment. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted May 12, 2017 I'd like to see a pic of the spacers fitted if you adjust the suspension...I'm still not convinced of their fitment. i will go & take some of it how it is in a bit if i can & of the rubbing too if i can capture it what do you mean when you say you are not convinced? do you mean that you are unsure if the 11.5mm ones will be ok? Quote Share this post Link to post Share on other sites
Geeba 0 Posted May 12, 2017 ....'Ferrado' as that is what my youngest son calls it :-) My youngest (3) calls mine 'The Old Banger' :( Quote Share this post Link to post Share on other sites
jamin 0 Posted May 12, 2017 i will go & take some of it how it is in a bit if i can & of the rubbing too if i can capture it what do you mean when you say you are not convinced? do you mean that you are unsure if the 11.5mm ones will be ok? Just the hub centric part - the disc has a shoulder that the wheel would originally locate on, I cant see how a narrow spacer could allow for this whilst also having a shoulder itself. Kinda hard to explain, which is why I'd like to see a pic if possible, not to worry if not. My youngest (3) calls mine 'The Old Banger' :( You need to educate them that its a 'classic' :-) Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted May 12, 2017 Just the hub centric part - the disc has a shoulder that the wheel would originally locate on, I cant see how a narrow spacer could allow for this whilst also having a shoulder itself. Kinda hard to explain, which is why I'd like to see a pic if possible, not to worry if not. You need to educate them that its a 'classic' :-) from what i recall the spacer sits on the outside of the disc not the inside as such the it means the spacer is what the wheel itself locates on to, rather than the shoulder on the disc, which is why hub centric spacers are recommended as they have the spigot shoulder on them for the wheel to locate i found ths out the hard way as i agreed to the cheap spacers HiSpec offered only to find they were not hub centric. which resulted in a call from my mechanic saying 'these spacers are tosh as they dont have a spigot to locate the wheel on' AFIK you can use non hub centric spacers but the wheel then only locates via the bolts does that makes sense to you m8? lol Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted May 12, 2017 here you go jamin.... spacers & then rubbing on arch liner, then shadow on tire from said rubbing Quote Share this post Link to post Share on other sites
jamin 0 Posted May 12, 2017 Thanks g0ldf1ng3r, that helps. I need to get a pair for the rear of mine. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted May 12, 2017 Thanks g0ldf1ng3r, that helps. I need to get a pair for the rear of mine. pleasure fella Quote Share this post Link to post Share on other sites
