g60kpj
Help needed!!
My G60 will not start!, if i turn the key two clicks the fuel injection buzzes as it should and then when i turn it fully to fire it up nothing happens at all just the injection buzzes again when the key is fully turned? I've tried bump starting it and arcing it from the starter but still no joy? Any help greatly appriciated!!
sounds like ignition to me mate check dizzy/coil / coil earth /plugs /leads etc etc
could also be a dodgey alarm system grounding the coil ?
cheers stu...
