corrado_sunderland
One dead rado :(:( wiring went nipples up HELP
went to get in the car tonite doors wouldnt open, thout it was the keyfob at first changed the battery and ther was nowt :cuckoo: . climbed through the boot and the ingition lights were all on without the key even been in,
opened the bonnet used jump leads and the car ran fine, remove the keys and she still ran and ran and ran, pulled relay 80 out and she cut out but still dash lights remain, tried every relay one by one and still dash lights on, wipers work, indicators everything works without the key except you can start the car on the push button without key been turned,.
The car goes flat quite quickly alsoas if power being drained as i not like the dash light will do it really. tried disconnecting all the ignition barrell set up while it was running and still kept goin, and the fuse box looks like a bowl of spag so i not even gunna touch that :sad:
any ideas here seems like a fused wire to me from what little electrical experience i have, this has just happend completely out the blue
The car is fitted with a clifford crappy alarm, the alarm has remote start enabled although every wire just about is bypassed in the hornets nest AKA my fuse box so nothing works anyway.
It's never done it before but just for the crak and a laugh the alram decided to give me car constant live, so another wire which is now removed out the alarm :cuckoo:
