BigTartanJudge
Fitting larger master cylinder ?
Hey all,
Fairly sure I have read somewhere (not here, and have done a search) in the past about people fitting a larger (23 mm ?) master cylinder to their rado or MK2 as it vastly improved pedal feel etc. Does anyone have any ino on this or know which model of vee-dub the master cylinder would have been from that they fitted ? Seeing as am doing everthing else to the brakes, it would be rude not to have the master and slave cylinders replaced at the same time,
Cheers
Aye, but I don't have a VR6 tho (G60 is 22mm isn't it ?), and I think the pedals are not interchangeable between the G60 one and VR6 one, so would need a new VR6 pedal too. As far as the MK4 one goes, is is a direct replacement to the G60 one and the pedal doesnt need to be adapterd or replaced with MK4 Golf one ?
